Reply
ktyson068
r6400v2 UPNP issues?
I have 2 xbox's connected through hardwire to my r6400v2 they have issues playing the same game together at the same time. My router is on its most recent firmware update, I did a factory reset earlier tonight. I am trying to avoid doing manual port forwarding because I have a rudimentary understanding of what I am doing and do not want to expose my network to any sort of security issues. I havew UPNP turned on but nothing ever populates in the portmap table.
Model: R6400|AC1750 Smart WiFi Router
Message 1 of 3
DarrenM
NETGEAR Moderator
Re: r6400v2 UPNP issues?
Message 2 of 3
ktyson068
I ended up using static IPs and port forwarding 3074 and one of the alternates. That seems to have done the trick. I think the actual issue is the firewall in the modem and my ISP has locked me out of adjusting the settings for that. Thank you for reaching out with that.
Message 3 of 3
Top Contributors
Discussion stats
  • 2 replies
  • 70 views
  • 0 kudos
  • 2 in conversation
Announcements
