Reply
r6900
tombrett
Follower
r6900
Are the LED lights supposed to be blinking, my internet LED blinks all the time, I just got this a few days ago.
Message 1 of 2
Guru
Re: r6900
Well you could be more specific which ones. the 2.4ghz and 5ghz leds blink when they're transmitting data. The power led blinks if the firmware is corrupt. Guest wifi blinks if sending/recieving data. USB led blinks when a usb device is trying to connect. Ethernet ports blink when sending/receiving data.
Page 13 of your manual goes over what the led lights mean.  here's where to get it.
https://www.netgear.com/support/product/R6900.aspx
Are you having problems or just curious?
Current Setup: CM2000-> RBK750-> GS716v2-> RAXE500-> Pi-hole->
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 189 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 6E
