Reply
r7000 and ready share
AceClark
Does Ready share use the internet? I only get a 1TB a month and I think that includes uploads.  Is there a way to disable this stupid Ready Share gimmick?  Its just too damn slow
Thanks!
Model: R7000|AC1900 Smart WIFI Router
Message 1 of 2
Guru
Re: r7000 and ready share
you can disable the usb port.
You go to ADVANCED > Advanced Setup > USB Settings and disable the USB port.
Current Setup: CM2000-> RBK750-> GS716v2-> RAXE500-> Pi-hole->
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 328 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 6E
