Reply
r7000 at two locations connecting to each-other as VPN
ENBertussi
Hey all,
I have no idea if this is so simple so maybe that is why I can find the answer, but years ago when I used to buy prosafe gear from netgear, connecting two routers to each other at two different locations to manage a rather automatted VPN that did not require desktop software was the way I used to set things up.
I can't find these settings on the R7000.
Maybe I am looking for something that is not there?
let me know
ENB..//
Model: R7000|Nighthawk AC1900 Dual Band WiFi Router
Message 1 of 5
Retired_Member
Not applicable
Re: r7000 at two locations connecting to each-other as VPN
tunneling if I recall was the option which is not available on the r7000
Message 2 of 5
ENBertussi
I used to deply the WG302 ProSafe, that was my go-to default router for at least a decade...
any idea what replaced it?
ENB..//
Message 3 of 5
TheEther
Guru
Are you sure?  The WG302 is listed as an Access Point, not a router.  Netgear's SOHO-class WAPs are here.
If you want something with IPSec tunneling capability, then you should look at one of their ProSafe VPN Firewalls.
Message 4 of 5
ENBertussi
Ya it could not have been the 302...
damn what was it?
ENB..//
Message 5 of 5
Top Contributors
Discussion stats
  • 4 replies
  • 2114 views
  • 0 kudos
  • 3 in conversation
Announcements
Orbi WiFi 6E
