- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
r7000 giving only hald of 1gbps fiber connection
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi guys, i am at the end of the road.
I have a 1gb full duplex fiber line. I had this with the same provider at my 2 previous adresses.
Now i moved to a new location, and my provider requires now:
- login
- password
- Vlan tagging
- and DNS servers (ip provided by provider)
they did not have this before and back then it was just plug and play and i got full 940mbps up/down.
Since the new login, i max out at about 420mbps up/down.
When i plug into the fiber converter, i get full speed, so its deffinitly the r7000.
I tried 10 different firmwares from newest to oldest and inbetween, dozens of factory resets.
I disabled basically everything from Qos, access/parent controll etc including all wifi
i tried different cables always the same...
any ideas?
Solved! Go to Solution.
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Permalink
Well i fixed my Problem by Flashing FreshTomate on my r7000, was a hassle untill i got everything up and running. I am maxing out at 900ish, so not 100% but ill take that over the OEM 450. Honestly **bleep** Netgear for not adding the simple solution to enable CTF.
All Replies
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: r7000 giving only hald of 1gbps fiber connection
Well i think i found the problem. That sounds exactly like me.
They fixed it for the R8000
https://kb.netgear.com/000060364/R8000-Firmware-Version-1-0-4-28
Netgear PLS fix for R7000 as well!
- Mark as New
- Bookmark
- Subscribe
- Permalink
