- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
r7000p power blinking orange after failed update
- Mark as New
- Bookmark
- Subscribe
- Permalink
I have read through some posts on this problem, is it just dead? it is just over a year old .
Solved! Go to Solution.
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Permalink
> I have read through some posts on this problem, [...]
Think for a moment about how little useful unformation that
non-description conveys to the non-psychics in your audience.
> [...] is it just dead?
Have you tried the TFTP recovery procedure?
All Replies
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: r7000p power blinking orange after failed update
I have attempted it a couple of times, the links in the procedure do not work
- Mark as New
- Bookmark
- Subscribe
- Permalink
> not work
The TFTP recovery procedure is a multi-step procedure with many
variables, and many opportunities for user error.
"attempted it" or "do not work" is not a useful problem description.
It does not say what you did. It does not say what happened when you
did it. As usual, showing actual actions with their actual results
(error messages, LED indicators, ...) can be more helpful than vague
descriptions or interpretations.
- Mark as New
- Bookmark
- Subscribe
- Permalink
It can take a little effort to get TFTP to work.
You might find it helpful to search for one of those YouTube videos:
unbrick my netgear router - Google Search
Take is slowly and pay attention to the exact details.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
> [...] Is that detailed enough?
It tells me all that I need to know.
- Mark as New
- Bookmark
- Subscribe
- Permalink
@cmccaghren wrote:
Sorry to not be to your level. So I will give you the exact procedure I did .I took the piece of **bleep** Netgear threw it in the **bleep**ing trash and went and bought a Linksys. Is that detailed enough?
Hopefully you will have good luck with the Linksys. Every consumer grade router has firmware issues it seems. Cannot really check Asus forums for their 'normal' routers only their gaming routers. Others seem to have issues similar to NG. NG does not seem to be testing the firmware before pushing out IMHO. Almost like a it loads so ship it.
