Reply
r7000p power blinking orange
Kohldavis
I tried updating via the mobile app multiple times but NEVER worked always said we can not update this firmware at this time. I then went to my computer and tried to update it there, then it had let me update. Mid way through it said connection lost and I went over to the router and it was blinking orange on the power symbol, ever since hasn’t stopped tried resetting, tried turning off and on, tried unplugging, tried unplugging modem and router. Nothing works. Honestly never had such an awful experience with a router, when it was working I had 200 ping when before switching I’d get 30-50. Should have gotten rid of it a long time ago but here I am giving it another chance. If anyone can help please do
Model: R7000|AC1900 Smart WIFI Router
Message 1 of 5
antinode
Guru
Re: r7000p power blinking orange
> [...] update. [...] blinking orange on the power symbol, [...]
   You may be a candidate for the TFTP recovery scheme.  See, for
example:
      https://community.netgear.com/t5/x/x/m-p/1622096
   Make sure that you get the right firmware kit for your actual model.
Message 2 of 5
Kohldavis
Thank you for the quick reply, and as I want to try that resolution I’m not exactly sure how to download that file without wifi... as my router is not working. I tried using hotspot but doesn’t work
Model: R7000P|Nighthawk AC2300 Smart WiFi Router with MU-MIMO
Message 3 of 5
antinode
Guru
> [...] I'm not exactly sure how to download that file without wifi...
> as my router is not working. [...]
   You posted this message here, so you must have some kind of Internet
access.  What's the problem?
> I tried using hotspot but doesn't work
   That tells me nothing, including exactly what you did, and what
happened when you did it.
Message 4 of 5
The R7000P is a router. So there is probably be modem in front of it.
If you have something that can plug into the router's wired LAN ports, maybe you can also plug it into the modem's LAN port. The you can get the file and begin the TFTP thing.
In any case, you will have to have to use a wired connection to the R7000P to use TFTP.
In general, experienced users try to avoid updating firmware over wifi. Too flaky, and likely to kill the thing if anything goes wrong.
Just another user.
My network DM200 -> R7800 -> GS316 -> PL1000 -> Orbi RBR40 -> Orbi RBS50Y -> RBS40V
Message 5 of 5
Top Contributors
Discussion stats
  • 4 replies
  • 673 views
  • 1 kudo
  • 3 in conversation
Announcements
Orbi WiFi 6E
