Reply
r7300 open vpn not working
CatzCatz
Hello, I setup the vpn with the gui in the router for openvpn. Download software and installed went to run openvpn from desktop and tryed to connect and just get a warning no cert found please help.
Thank You
Message 1 of 13
JamesGL
Master
Re: r7300 open vpn not working
Hi CatzCatz,
Check the Kb article below for the steps on how to configure OpenVPN.
http://kb.netgear.com/app/answers/detail/a_id/23854/~/how-do-i-use-the-vpn-service-on-my-nighthawk-r...
JamesGL
Community Team
Message 2 of 13
JamesGL
Master
Hi CatzCatz,
We’d greatly appreciate hearing your feedback letting us know if the information we’ve provided has helped resolve your issue or if you need further assistance.
If your issue is now resolved we encourage you to mark the appropriate reply as the “Accepted Solution” so others can be confident in benefiting from the solution. The Netgear community looks forward to hearing from you and being a helpful resource in the future!
JamesGL
Community Team
Message 3 of 13
CatzCatz
I did all that and it still doesn't work all i get is warnning cert can not be found
Message 4 of 13
JamesGL
Master
Hi CatzCatz,
1. Where is the Desktop connected? Make sure it is not connected within the network of the R7300.
2. Please provide the logs of the OpenVPN.
JamesGL
Community Team
Message 5 of 13
CatzCatz
Enter Management Password:
Sun Nov 20 21:36:23 2016 WARNING: No server certificate verification method has been enabled. See http://openvpn.net/howto.html#mitm for more info.
Sun Nov 20 21:37:26 2016 WARNING: No server certificate verification method has been enabled. See http://openvpn.net/howto.html#mitm for more info.
Sun Nov 20 21:38:28 2016 WARNING: No server certificate verification method has been enabled. See http://openvpn.net/howto.html#mitm for more info.
Sun Nov 20 21:39:30 2016 WARNING: No server certificate verification method has been enabled. See http://openvpn.net/howto.html#mitm for more info.
Above is the log file.
Thank You
Message 6 of 13
JamesGL
Master
Hi CatzCatz,
Please PM me the complete logs of your OpenVPN.
JamesGL
Community Team
Message 7 of 13
DRCNTX
I have the exact same problem.  What was / is the resolution for this?  Thanks!
Model: R7800|Nighthawk X4S AC2600 Wifi Router
Message 8 of 13
Alvintc
Yep, same here as well...
Message 9 of 13
JamesGL
Master
Hi Alvintc,
PM me the logs of your OpenVPN.
Message 10 of 13
guwitpro
i tried this http://kb.netgear.com/app/answers/detail/a_id/23854/~/how-do-i-use-the-vpn-service-on-my-nighthawk-r...
Did not work,
 i still tried on other solution adding ;
;dev-node NETGEAR-VPN
did not work..
still having the same error
Wed Jan 25 11:02:06 2017 WARNING: No server certificate verification method has been enabled. See http://openvpn.net/howto.html#mitm for more info.
Message 11 of 13
huanghe_78728
I have exact same problem. How to solve it? Thanks.
Message 12 of 13
JamesGL
Master
Hi All,
I would suggest contacting support to better isolate your issue.
https://www.netgear.com/support/contact.aspx?cid=wmt_netgear_organic
Message 13 of 13
Top Contributors
Discussion stats
  • 12 replies
  • 3110 views
  • 0 kudos
  • 6 in conversation
Announcements
