Orbi WiFi 7 RBE973
Reply
r7500 5ghz stopped working
chaufosho
Tutor
hey guys
so i have the r7500 and when i first set it up it was working fine, firmware version 1.0.0.94 and today it suddenly dropped the 5ghz band, 2.4 is working fine, im not sure what is wrong. the 5ghz band isn't broadcasting or showing up, i've reset my router and settings but still no fix.
Model: R7500|Nighthawk X4 AC2350 Smart WiFi Router
Message 1 of 9
Accepted Solutions
JamesGL
Master
Re: r7500 5ghz stopped working
Hi chaufosho,
1. Check the wireless settings under advanced and make sure that "enable router radio" is checked on 5Ghz.
Message 5 of 9
All Replies
HiSpeed
Guide
Hi,
Are you sure there si no more 5GHz signal, I mean with a scan test from another machine (android tablet for example) ?
Message 2 of 9
chaufosho
Tutor
Yea tried on my phone, Computer, and tablet no 5ghz signal, the light on the router for the 5ghz isn't on either, tried all the settings on the net gear genie still no luck
Message 3 of 9
HiSpeed
Guide
That sounds not good to me, you've probably to ask a RMA...
Message 4 of 9
JamesGL
Master
Hi chaufosho,
Message 5 of 9
JamesGL
Master
Hi chaufosho,
We’d greatly appreciate hearing your feedback letting us know if you need further assistance.
Message 6 of 9
chaufosho
Tutor
i checked all that in advance setting, doing am RMA now
Message 7 of 9
chaufosho
Tutor
router radio is enable still not working
Message 8 of 9
JamesGL
Master
Hi chaufosho,
Provide us an update once you receive the replacement unit.
Message 9 of 9
Top Contributors
Discussion stats
  • 8 replies
  • 5348 views
  • 1 kudo
  • 3 in conversation
Announcements
Orbi WiFi 7
