Reply
r8000 connection internet connection
dgastacct
Since R8000-V1.0.4.28_10.1.54.chk I am constantly dropping internet connection.  Verified not the the ISP, this is happening at this device, since last update.
Anyone else?  If there is not an update soon and trashing this device.
Model: R8000|Nighthawk X6 AC3200 Smart WIFI Router
Message 1 of 3
Rosuck25
Re: r8000 connection internet connection
Drops connection and app will not connect. Speed test helps it connect .
Message 2 of 3
Guru
A couple things you can try.
1. Did you do the update over a hardwired connection? If not, do it over a hardwired connect.
2. Did you reset afterward. I've always done a reset after updating and had great results. A backup helps for redoing the setup after updates.
3. If these don't work, you can always downgrade the firmware to an earlier version. the support page has under downloads the "+view previous versions". Just follow the manual install procedures.  Again make sure to do it over a hardwired connection and to reset afterward.
https://www.netgear.com/support/product/r8000.aspx
Current Setup: CM2000-> RBK750-> GS716v2-> RAXE500-> Pi-hole->
Message 3 of 3
Top Contributors
Discussion stats
  • 2 replies
  • 258 views
  • 0 kudos
  • 3 in conversation
Announcements
Orbi WiFi 6E
