Reply
r8000 "wireless" wont turn on
jerrydtm
So i have the r8000 I got from a from a friend to try to fix. the problem is the "wifi" doesnt work. I have tried everything from pressing the wifi button on the router for 2 seconds all the way to a hard reset. so far nothing has allowed the wifi to work. anything plugged into the lan works but no wifi.
lights are all white and show 2.4 and 5 is supposed to be on.
Model: R8000|Nighthawk X6 AC3200 Smart WIFI Router
Message 1 of 4
Guru
Re: r8000 "wireless" wont turn on
Have you tried reinstalling the firmware (or downgrading) and then doing a factory reset?
If the firmware was corrupt, sometimes a reinstall is needed
Current Setup: CM2000-> RBK750-> GS716v2-> RAXE500-> Pi-hole->
Message 2 of 4
jerrydtm
i did update it when it first booted. but that sounds like it could work.
any chance you can walk through how to do that?
Message 3 of 4
Guru
go to the support site for your device here: Nighthawk X6 R8000 | AC3200 Tri Band Router | NETGEAR Support
The click on downloads. Then "view previous versions" That'll have older versions. Download the one you want and extract it. Then follow the manual update guide but use the firmware you downloaded and not the newer versions.
How do I manually update the firmware on my NETGEAR router? | Answer | NETGEAR Support
Message 4 of 4
Top Contributors
Discussion stats
  • 3 replies
  • 167 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 6E
