Reply
rax 120 cm1200 wan aggregation and lan aggregation help with gaming
Seanabong2200
Apprentice
Hello everyone I have a RAX120 and CM1200 modem. Was curious to know if setting up wan or lan aggregation will help with gaming network speeds/ping. Just curious to know if it will help in anyway when it come to gaming. Right now i game on a xbox one x. and my console is currently connected to the 5gbs lan port on the router dmz is active for my console and i have designated a ip address to the console. usaully i have a ping from the console around 40 to 50. download speeds 550gbs and upload around 25gbs when testing from the console itself.
Model: CM1200|Nighthawk Multi-Gig Speed Cable Modem, RAX120|Nighthawk AX12 12-Stream WiFi Router
Message 1 of 2
Guru
Re: rax 120 cm1200 wan aggregation and lan aggregation help with gaming
I would avoid it at this time. Especially if you don't have >1gig speeds. Wan aggregation has had issues for a while if you search the forums.
https://community.netgear.com/t5/Nighthawk-Routers-with-WiFi-6-AX/CM1200-to-Rax200-WAN-aggregation-s...
CM2000-> RAXE500-> GS716v2-> WAX218-> EX8000
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 283 views
  • 0 kudos
  • 2 in conversation
Announcements
