Orbi WiFi 7 RBE973
Reply
readyShare does not allow me to connect to my HDD
Savier
Tutor
Im not sure that I put the rounter name correctly, but if not, my router name is NighthawkAX8AX6000 WiFI Cable Modem
Router, Model CAX80. So before readyShare allowed me to connect to my HDD with the USB behind the modem router. I don't know if it updated and that caused the problem because I did not update the firmware. If it did it might of came from the ISP, the current firmware version I have is V2.1.2.6, and when I check for an update, I can't find no new update. I also have issue with the router/modem when I restart it, it asks me for a new password and a securtiy questions everytime I restart it, but thats for another discussion. please if you guys know whats going on or if I'm doing something wrong, please let me know,
Thank you
Model: RAX80|Nighthawk AX8 8-Stream WiFi Router
Message 1 of 3
Guru
Re: readyShare does not allow me to connect to my HDD
Netgear has set up a community forum specifically for the Cable Modem Gateway products. Most of the people who watch that forum are more likely to have experience with Orbi AX and know how to work it better than those of us who follow this "Nighthawk WiFi Routers" forum. Might be more likely to find someone who has a solution if the question is posted there:
https://community.netgear.com/t5/Cable-Modems-Routers/bd-p/home-cable-modems-routers
Thank you.
Message 2 of 3
Savier
Tutor
Okay, thank you
Message 3 of 3
Top Contributors
Discussion stats
  • 2 replies
  • 283 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
