hndaownr's avatar
hndaownr
Follower
Nov 12, 2022
readyshare drive renaming
We recently decided to upgrade to a newer Netgear Nighthawk router. It works perfectly. However, try as I might I can't rename either of my readyshare usb drives. I can go into the admin profile, rename the drives; edit; apply. The share name *looks* like it has changed, however, when I click apply again (the one above help center) the name has reverted back. I'd rather not have the share be called USB Storage. Since the "folder name" is U, I'd like for the share to be "U_Drive." I'm hoping that this change is possible.
No RepliesBe the first to reply
