Reply
readyshare issues
dkhey
readyshare issues
In the history of owning this router, I have not been able to connect a Brother HL5340 printer via USB and use it over the network. When I open the USB control center on PC or Mac, nothing appears at all. I have used these printers on all of my machines via USB direct to each machine and have the drivers installed. Any advice?
I have installed the freshest firmware as of today.
Model: R8000|Nighthawk X6 AC3200 Smart WIFI Router
Message 1 of 8
dkhey
Re: readyshare issues
Update - I got it to work on OSX; however, the connection will not stay connected and it disappears from the USB Control Center.
Message 2 of 8
it_geek
Change the default timeout to 600 seconds.
Proud Owner of an R8000 since August 2014!
Message 3 of 8
OlegP
Apprentice
ReadySHARE is completely broken, at least on Windows.
Here is a post that I made about the issue. 0 response from Netgear.
https://community.netgear.com/t5/Nighthawk-WiFi-Routers/Netgear-ReadySHARE-has-been-broken-for-2-yea...
I was able to get a hold of a Netgear rep over on snbforums; however, and it sounds like ReadySHARE is unlikely to get fixed any time soon, if ever.
I've also encountered a severe bug with QoS. Here is my post.
https://community.netgear.com/t5/Nighthawk-WiFi-Routers/R8000P-Dynamic-QoS-Stops-Working-After-a-Few...
Again, 0 response from Netgear.
Tomorrow I'm returning the X6S that I've owned for less than 2 weeks. Last Netgear product that I will purchase in my lifetime.
I recommend that you do the same.
Message 4 of 8
OlegP
Apprentice
Oh and I almost forgot. The router loves to disconnect my WiFi Apple devices after they sit at idle for a day. It could be the smart connect. Could be the mumimo. Could be Carole Baskins. Who knows. Who cares anymore. I know that Netgear doesn't.
Truly a gift that keeps on giving.
Message 5 of 8
it_geek
I haven't had issues using ReadyShare on Windows. Usually I need to tweak my firewall settings and that's it.
Message 6 of 8
OlegP
Apprentice
Are you using Win 7?
Message 7 of 8
it_geek
Btw. Try enabling SMB v1. NETGEAR USB Control Center appears to need it. Go under Programs and Features >> Add a new feature in Windows.
Message 8 of 8
Top Contributors
Discussion stats
  • 7 replies
  • 779 views
  • 0 kudos
  • 3 in conversation
Announcements
Orbi WiFi 6E
