Reply
replaced router reusable?
TexasIndian
Tutor
Waiting to purchase new AX router "coming soon", which will replace current router.
Speaking 'techno-inept', what ALL does it take to:
1. erase existence of current router just before installing new AX?
2. how can the current one be 'reused' once new one delivered?
    In other words, I want to give it to daughter+family; what steps
    do I/she follow to 'pass it on' to her & install (they're still using a 'N')?
Model: R7000|AC1900 Smart WIFI Router
Message 1 of 7
Accepted Solutions
Guru
Re: replaced router reusable?
If its factory reset, the new user would just need to follow the install guide.
For the R7000, it can be found here:
https://www.netgear.com/support/product/R7000
Current Setup: CM2000-> RBK750-> GS716v2-> RAXE500-> Pi-hole->
Message 4 of 7
All Replies
DarrenM
Sr. NETGEAR Moderator
You will just need to hold the reset button for 10+ seconds on the router. Then they would be able to set the router up like new.
DarrenM
Message 2 of 7
TexasIndian
Tutor
Excellent, thanks DarrenM,
Now, THAT clears the router...how do I erase all (current) Netgear files? Genie? Etc?
(assume all SHE will do is connect her 'new' router and Genie will take from there & install)?
Message 3 of 7
Guru
Message 4 of 7
TexasIndian
Tutor
Thank you so much plemans,
I can't imagine how much my daughter/grandson's will appreciate the 'upgrade'
(so Mr. Guru..take a look at my other query...what/how do I 'erase' all the old
1900/Netgear data/etc stored in computer when I install the new (AX) router?)
Message 5 of 7
Guru
You can always uninstall the genie if you're using an installed version.
I usually don't use the installed genie. I tend to just log in through the browser for setup/changes.
Message 6 of 7
TexasIndian
Tutor
knowledge always appreciated...will very likely be forwarding more questions to you soon
(like next week when grandkids IN school) when trying to install new router/uninstall old one
Message 7 of 7
Top Contributors
Discussion stats
  • 6 replies
  • 407 views
  • 3 kudos
  • 3 in conversation
Announcements
Orbi WiFi 6E
