Reply
router blocks AOL
HVACDR
Follower
router blocks AOL
This router blocks AOL.com. This is the only web site that its blocking, why?
Model: R8000|Nighthawk X6 AC3200 Smart WIFI Router
Message 1 of 4
IrvSp
Master
Re: router blocks AOL
How do you know this? How are you alerted to this other than it possibly not loading?
It works fine on my R8000?
Questions:
  1. Has it worked before with a different router?
  2. Does it work if connected directly to modem?
  3. Have you cleared the browser cache?
  4. Can you PING AOL.COM?
  5. Do you get an error code and if so, what is it?
  6. Have you tried a different browser?
  7. Are you using the AOL Desktop app, if so try a browser?
  8. Could you Fire Wall be doing this and not the router, try disabling it momentarily and see.
Message 2 of 4
Tried a different browser?
Is that is what you are using.
Given how much information you have provided, who knows?
Just another user.
My network DM200 -> R7800 -> GS316 -> PL1000 -> Orbi RBR40 -> Orbi RBS50Y -> RBS40V
Message 3 of 4
schumaku
Guru
AOL.com blocked in the keyword blocking? Check [Advaced] -> Security -> Block Sites
Message 4 of 4
Top Contributors
Discussion stats
  • 3 replies
  • 441 views
  • 0 kudos
  • 4 in conversation
Announcements
