Reply
router not working
akborhossain
Follower
router not working
HI MY ROUTER WAS GOOD. BUT I TRY TO UPDATE FIRMWARE BUT WHEN SUDDENLY MY ELECTRY GONE AND AFTER THEN ROUTER ONLY SHOWING WELLOW LIGHT AND NOT WORKING NOTHING
SO WHAT TO DO
Model: R6120|AC1200 Dual Band WiFi Router
Message 1 of 2
Guru
Re: router not working
1. use caps lock appropriately. tough to read when everything is capitalized and I feel like your shouting.
2. What led is yellow?
3. power dying during an upgrade can be an issue.
You can try recoving it with tftp or nmrpflash.
are you on windows? if so, follow this guide
https://kb.netgear.com/000059634/How-to-upload-firmware-to-a-NETGEAR-router-using-Windows-TFTP
just make sure you enable tftp
https://www.thewindowsclub.com/enable-tftp-windows-10
and here's a video walk through using a tftp client. Use the built in one for windows 10 though. the video is more of an example of how its done.
https://www.youtube.com/watch?v=R9DLrLQrpaw
and if that doesn't work, you can try using nmrpflash
https://github.com/jclehner/nmrpflash
Current Setup: CM2000-> RBK750-> GS716v2-> RAXE500-> Pi-hole->
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 129 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 6E
