pokalsing's avatar
pokalsing
Follower
Apr 26, 2022
router question from a noob
I live and work in China. The internet here has many restrictions. I currently have 2 netgear routers, one is connected to the other via an ethernet cable. This way I can have 2 wifi signals in my house. On the second router, I flashed DD WRT and am running Astril VPN.
My old internet speed was 100 MB and today I just upgraded to 1,000 MB.
I already ordered an Asus RT AX88U wifi 6 router (64 bit Quad Core @ 1.8 Ghz, RAM 1024 MB, and 256 Flash). My older router is a Netgear Nighthawk R7000. (600 +1300 mbps, AC1900, Processor 1GHZ, 256 MB Ram and 128 MB Flash).
Question 1 - Do I need 2 wifi 6 (newer more power routers) in order to benefit from the 1 GIG net speed?
Question 2- Current setup Asus RT AX88U and Netgear R7000 routers. Whiche one should I run the Chinese net as the main one and which one should I use as the VPN router? I plan to flash the Asus with Merlin.
Question 3- Since the Netgear is an older model... Will it slow down the internet speed of the Asus should I choose to have the Asus be the VPN router bc its faster?
Please... any helpful comments would be apprecate. Excuse the long post.
Thank You.
No RepliesBe the first to reply
