Reply
router r 7000 can connect with gs 808 e ?
retraite
do i need port aggregation on my router?
Message 1 of 5
schumaku
Guru
Re: router r 7000 can connect with gs 808 e ?
Bandwidth requirements permitting, a single Gigabit Ethernet connection into the router can be sufficient. It's not mandatory to have any LAG or port aggregation between the switch and router.
Message 2 of 5
antinode
Guru
   You do, if you expect to use it on the connection between the GS808E
and your "my router".  So far as I know, the R7000 lacks that feature,
so I don't see how you could use it for a link between these devices.
   Whether such a faster link would actually help you is another
question.  The WAN/Internet port on the R7000 would still be a single
gigabit interface.  Even if you could do it, what would such a faster
router-switch link do for you?
Message 3 of 5
schumaku
Guru
@antinode a R7000 has multiple GbE ports plus a WAN plus two WLAN interfaces - so plenty of channels which might require more than one Gigabit channel.
Message 4 of 5
scjay
You do not “Need” it and I use the uplink port to connect to my router. I actually use the port aggregation on the switch to connect my NAS that has 2 Ethernet ports configured for aggregation. There nothing that says you need to port aggregation at all and there are default configurations without it enabled.
Message 5 of 5
Top Contributors
Discussion stats
  • 4 replies
  • 409 views
  • 0 kudos
  • 4 in conversation
Announcements
