Reply
timmyj76
Follower
security questions don't match
does anyone know what to do if your security quetions answers don't match
Message 1 of 2
labatt
Prodigy
Re: security questions don't match
If you don't know the password then your only option is to reset the router. This puts it back to the default config that was on it out of the box. Then you will need to do a new config.
When you press reset you need to hold in for 7-10 seconds or until lights start flashing. Netgear broke the password recovery option.
Modem CM2050V
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 74 views
  • 0 kudos
  • 2 in conversation
Announcements
