Reply
setup auto disconnect for wan help
capa
Novice
I have comcast and they have a 300gb monthly limit... I was wondering if there is a way to setup my router to turn off internet connection after X amount of data to avoid charges. Thanks!
Message 1 of 4
jmizoguchi
Virtuoso
Re: setup auto disconnect for wan help
There is no options do that like Proafe/Prosecure model does
http://interface.netgear-forum.com/FVS336G/traffic_meter_wan1.htm
Monthly Limit text box. Once the limit is reached, no traffic will be allowed from the WAN side.
VPN Case Study
VPNCASESTUDY.COM
"Our Second To None VPN Related Setup Case Study[/COLOR][/URL]
"One Stop Solution To Your Netgear VPN Connectivity"
*Visit the site for Non-VPN related Doc & Links* [Windows & Mac user/support]
June Mizoguchi-
Message 2 of 4
Retired_Member
Not applicable
Traffic meter under advanced setup is where that option is.
Message 3 of 4
Almighty1
Novice
Look under Advanced Setup -> Traffic Meter where you can do: Traffic volume control by download only, upload/download and then specify the monthly limit megabytes. then you have the options of: Traffic Control Pop up a warning message x Mbytes/Minutes before the monthly limit is reached When the monthly limit is reached with the following two options: Turn the Internet LED to flashing green/amber Disconnect and disable the Internet connection
Message 4 of 4
Top Contributors
Discussion stats
  • 3 replies
  • 8153 views
  • 0 kudos
  • 4 in conversation
Announcements
