Orbi WiFi 7 RBE973
Reply
setup
Timeghost
Initiate
setup
Everthing I read about the setup for this starts with "Download the Nighthawk app to your smartphone."
I don't have a smartphone, and have no plans to get one.
Now what? How do I set this up?
Model: R6080|AC1000 Dual Band WiFi Router
Message 1 of 3
Accepted Solutions
antinode
Guru
Re: setup
> Everthing I read about the setup for this [...]
   For the non-psychics in your audience, what, exactly, is everything
you read?
   I don't know how _you_ do it, but some people have met with some
success using this oft-neglected concept:
      https://en.wikipedia.org/wiki/RTFM
   Visit http://netgear.com/support , put in your model number, and look
for Documentation.  Get the User Manual (at least).  Read.  Look for
"Use a Web Browser to Access the Router".  Further reading might not
hurt, either.
   Even the Quick Start guide explains where to find "user manuals".
It's not a well-kept secret.
Message 2 of 3
All Replies
antinode
Guru
Re: setup
you read?
hurt, either.
Message 2 of 3
Timeghost
Initiate
Re: setup
Thank you for your sarcastic, condescending answer; it was very helpful.
Message 3 of 3
Top Contributors
Discussion stats
  • 2 replies
  • 667 views
  • 2 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
