- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
stop working
- Mark as New
- Bookmark
- Subscribe
- Permalink
stop working
my wifi router stop working the internet light is on but no internet. I have a nighthawk R7000is it broken do need a another.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: stop working
what modem/gateway is it connected to ?
What firmware is on the router?
What actual error are you getting? Connected, no internet? Is the wifi broadcasting at all?
Do wired devices work?
What have you tried doing to fix it? reboot the modem/router? Factory reset the router and reinstall it?
What changed?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: stop working
netgear modem
fimware can`t remember the number
no internet
wired work
yes have rebooted
changed nothing
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: stop working
Do another hard reset by pressing the reset pinhole with a paper clip. Before rebooting the router, restart your modem and wait til it syncs up with the internet. When the internet lights up then connect the router to the modem and see if that fixes it.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: stop working
@oldergeek wrote:
netgear modem ----which one?
fimware can`t remember the number ----so look it up on the device
no internet---not even slightly helpful. Doesn't tell me whats happening with the wifi, leds, if its broadcasting, connecting to modem, etc.
wired work ---yaaayyy! actual info
yes have rebooted
changed nothing
do you see how little this helped? We're not psychic. We don't know your setup. We don't know what you're seeing or whats going on with your network without details. So help us to help you. Give us details. put the time/effort into that we are. If you don't have the time for it, then feel free to go through support.
To get a hold of support. Click on "MyNetgear" at the top.
Register an account (or login) and then the device.
From there you can start the support process. Keep in mind that its only free for the first 90 days.
