Reply
torrent magnet link r7800 v1.0.2.52 not working
kabudi
Luminary
BitTorrent Link not working ,not adding up to download task list after pressing add (after upgrading to 1.0.2.52).
Model: R7800|Nighthawk X4S AC2600 Wifi Router
Message 1 of 3
Re: torrent magnet link r7800 v1.0.2.52 not working
Did you reset the router to factory settings after the firmware flash?
New firmware sometimes introduces changes that are not compatible with the old configuration.
So while it isn't guaranteed to fix problems a factory reset is the first thing to try if you have issues with new firmware.
Just another user.
My network DM200 -> R7800 -> GS316 -> PL1000 -> Orbi RBR40 -> Orbi RBS50Y -> RBS40V
Message 2 of 3
kabudi
Luminary
ok i will try .
thanks
Message 3 of 3
Top Contributors
Discussion stats
  • 2 replies
  • 1658 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 6E
