Reply
unable to register product - already register by an unknown person
beepee
Hi,
When I try to login to the router the default admin / password are invalid .
So I tried to register the router with Netgear and I am getting the following message "This Serial number has already been registered in our system by a support representative".
It's brand new out of the box today???
Anybody any suggestion other than pay 49 dollars for support from Netgear??
Thanks in advance.
Bill
Model: R7000|Nighthawk AC1900 Dual Band WiFi Router
Message 1 of 3
JamesGL
Master
Re: unable to register product - already register by an unknown person
Hi beepee,
You should not be paying support for just product registration.
Message 2 of 3
Ngato8
Had the same thing happen to me with an R8000P. Bought from Amazon, arrived with no cellophane on box. When I went to set up, not standard ip address but 10.100.0.1. Non standard password too. Factory reset. Got it working. Went to register and found out SN was registered to a netgear support tech. Danced with them, no one had any idea how a used item entered the retail stream. Amazon returned no problem. The router was to replace a bricked R8000 that I can't fix.
I'd advise you do the same.
Model: R8000P|Nighthawk X6S—AC4000 Tri-Band WiFi Router
Message 3 of 3
Top Contributors
Discussion stats
  • 2 replies
  • 361 views
  • 0 kudos
  • 3 in conversation
Announcements
Orbi WiFi 6E
