Reply
update V1.0.5.36
CLAIREWp3
Tutor
update V1.0.5.36
Our router constantly stays on 60GHZ since the update and the router is constantly restarting since the update - nothing shows on the logs so it can only be the update as we had no issues before update  V1.0.5.36.
Model: R9000|Nighthawk X10 AD7200 Smart WiFi Router
Message 1 of 9
Accepted Solutions
CLAIREWp3
Tutor
Re: update V1.0.5.36
Thank you, the downgrade (down to the previous version) worked last night and had no issues since.
Message 8 of 9
All Replies
Guru
Have you tried a factory reset and reinstall?
Or tried downgrading the firmware?
Current setup: CM2000-> RBKE963B-> Trendnet TEG-S380-> GS716T-> pi-hole
also in AP setup: RAXE500->EAX80
1.4gig download/50mbps upload from Xfinity
We’re members of the public helping out on our own time.
Message 2 of 9
CLAIREWp3
Tutor
I looked online and could only find V1.1.0.18 - tried installing that and what a mess it really did not like it, gave me constant "trying to configure" window.
I would prefer not to factory reset
Message 3 of 9
Guru
Not sure where you were looking but you can get the current and all the older firmwares on the support site.
https://www.netgear.com/support/product/R9000.aspx
Message 4 of 9
CLAIREWp3
Tutor
best steps for downgrading?
Message 5 of 9
Guru
  • download the version you want
  • extract it
  • manually connect a pc/laptop to your router (disable the pc/laptops wifi)
  • follow the manual firmware update process but use the firmware you downloaded
  • *optional but recommended* factory reset the router and reinstall.
Message 6 of 9
.... and read this.
How do I manually upgrade firmware to my NETGEAR router? | Answer | NETGEAR Support
Just another user with a set of boilerplate macros.
My network DM200 -> R7800 -> GS316 -> PL1000 -> Orbi RBR40 -> Orbi RBS50Y -> RBS40V
Message 7 of 9
CLAIREWp3
Tutor
Message 8 of 9
Guru
Glad to hear it fixed it! If you mark it solved, it might help the next person with this issue
Message 9 of 9
Top Contributors
Discussion stats
  • 8 replies
  • 695 views
  • 2 kudos
  • 3 in conversation
Announcements
Orbi WiFi 6E
