Reply
using x6/x8/x10 guest network feature with multiple ssid and vlan
dangermaus
hello,
i have an existing home network which has multiple access points controlled by a ruckos zone director.
currently this aggregates the ap's and provides the ssid which devices connect to. the ssid provided by the router is not used, it provides internet access and tcp network.
would it be possible to create a separate vlan on any nighthawk to allow me to provide two network ranges to the aggregator and broadcast two ssid's from the ap's? basically want to create a guest network without devices connecting directly to the nighthawk.
thanks
samuel
Message 1 of 2
ElaineM
NETGEAR Employee Retired
Re: using x6/x8/x10 guest network feature with multiple ssid and vlan
Welcome to the community, @dangermaus
The Nighthawk routers have Guest Network and the Main Network.
The Guest Network will only have Internet access and nothing else unless you tell them that they can access your local network by checking a box.
ElaineM
NETGEAR Community Team
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 2435 views
  • 0 kudos
  • 2 in conversation
Announcements
