Reply
wifi channel protection
kuenn
Follower
while troubleshooting network on reason for my wifi network keep dropping connection.
i noticed that a very specific SSID "SINGTEL-DABF" keep jumping from one channel to another.
it is also exhibiting very strong signal strength. it is even stronger than my wifi when i was in the living room directly 3 meter from my router.
this cause some concern, all will to know how do i identify this rogue wifi and protect my wireless network.
Model: R7800|Nighthawk X4S AC2600 Wifi Router
Message 1 of 4
TheEther
Guru
Re: wifi channel protection
It could be a neighbor's network and their router is using auto channel selection. Log into your router and change the channel from auto to a fixed number. This will hopefully make your network more stable.
Message 2 of 4
JamesGL
Master
Hi kuenn,
Please check this KB article on selecting channels.
http://kb.netgear.com/app/answers/detail/a_id/1027/~/selecting-wireless-channels
Message 3 of 4
VE6CGX
Master
Designated public spectrum is that of wireless we use. Thart is not rogue signal, just strong affecting yours. Is there a reason you think that is
rogue? One way to counter this kind of issue is using 5GHz band which is not so crowded yet.
Message 4 of 4
Top Contributors
Discussion stats
  • 3 replies
  • 2072 views
  • 0 kudos
  • 4 in conversation
Announcements
