Reply
wifi password reset
idowjwd
Follower
wifi password reset
How does one go about changing the wifi password people use to login to the router?  I changed the password to this account, but it does not have anything to do with the wifi password aparently.  I don't see a place to change that password.
Message 1 of 2
Guru
Re: wifi password reset
this is how to change the admin login password.
How do I change the admin password on my NETGEAR router? | Answer | NETGEAR Support
and this is for wireless ssid/password.
How do I change my NETGEAR router password or network name (SSID)? | Answer | NETGEAR Support
Current Setup: CM2000-> RBK750-> GS716v2-> RAXE500-> Pi-hole->
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 109 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 6E
