- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
wired connection keeps dropping out
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
My computers wired connection keeps pausing on the router upto several times a minute. I have tried other router ports and problem remains. If I hook the computer directly to my cable modem the connection remains stable. I cannot find any settings in the mobile app or on the netgear genie to prevent this from occurring.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
Re: wired connection keeps dropping out
Try replacing the ethernet cable to see if that helps?
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
R6400 or R6400v2?
Reason I ask is that the R6400v2 recieved the netgear armor update. it didn't go well for everyone. many fixed the issues with a simple factory reset and manual re-install. some have had to downgrade the firmware to prior to armor and reinstall.
So which version are you on?
Firmware that you're on?
What modem are you using?
1.4gig download/50mbps upload
We’re members of the public helping out on our own time.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
I have the r6400 V2
firmaware version: 1.0.4.84_10.0.58
xfinity cable modem
should i go through the factory reset and not update the firmware?
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
The version of firmware that you're on supports netgear armor. If you haven't, I'd start off with a factory reset and try that.
if you still get the same issue, you can try downgrading to prior to armor. should be version 1.0.3.66.
what xfinity modem are you using? Some are combo devices which would put you in a double nat and could be causing your issue and not netgear armor.
https://kb.netgear.com/30186/What-is-Double-NAT
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
I did the factory reset; however, I am not sure how to roll back firmware. regardless things are stable now. If the problem crops up again i will check the cable modem settings and ensure it is setup as a bridge to remove the double NAT.
thanks!
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
Glad to hear you have it working right again!
