Orbi WiFi 7 RBE973
Reply
wireless network found as DSW50
Hober
Follower
installed new Aris modem.  PC via ethernet connects to web.  Cannot achieve wireless connection with iPhone, smart TV, Alexa.
phone shows network as DSW50 and DSW24.  Have no idea origin of those networks.
Model: WNDR3400|N600 Wireless Dual Band Router
Message 1 of 3
Guru
Re: wireless network found as DSW50
Are you sure thats your wireless SSID?
Did you try factory resetting and reinstalling the device?
Is this a new router? (new to you, its over a decade old)
https://www.netgear.com/support/product/WNDR3400v1.aspx
Message 2 of 3
Guru
Please post about this here for your model router:
https://community.netgear.com/t5/General-WiFi-Routers-Non/bd-p/home-wifi-routers-general
Good Luck.
Message 3 of 3
Top Contributors
Discussion stats
  • 2 replies
  • 369 views
  • 0 kudos
  • 3 in conversation
Announcements
Orbi WiFi 7
