- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
2.4 GHz and 5 GHz WiFis not the same network?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Kids got PS5 as xmas present and daughter also got Just Dance 2022 game which is controlled with a smart phone app. When we installed the console and the game, everything worked fine. The next day, we just couldn't connect the smart phone app with the game. Shooting from the hip, I disabled the AX feature from the router config and then it worked. But next time we again couldn't connect. So turned out AX is not the issue. After hitting my head against the wall for a while, I realized that the console was on 5 GHz WiFi and the phone on 2.4 GHz. I connected the console to the router with a LAN cable and since then we haven't had any issue with the connection. Now to the question - is it a bug or a feature? The game instructs that the phone and the console have to be in the same LAN or WiFi. If LAN + WiFi 2.4 GHz are in the same network then why aren't WiFi 2.4 GHz and WiFi 5 GHz? And if it's a bug then is in the router, in the console or in the game?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: 2.4 GHz and 5 GHz WiFis not the same network?
Is Smart Connect enabled on the router?
Did you try disabling Smart Connect and set up separate SSID names for each freqency then connect both of these devices to same frequency to see what happens?
My Setup | ISP SparkLight | Internet Cable 1000↓/50↑ CAX30 Mode Mode | Wifi Router XR500 and RBK863 Router mode | Switches NG GS105/8, GS308v3, GS110MX and XS505M | Additional NG HW: C7800/CAX3/CAX80/CM1100/CM1200/CM2000, Orbi: CBK40, CBK752, RBK50, RBK853, RBK752, RBK953, SXK30 | NightHawk: MK63, R7000, R7800, R7960P, R8000, R8500, RAXE500, RAX120v2, RAX50v2, XR450/500/700/1000, EX7500/EX7700
- Mark as New
- Bookmark
- Subscribe
- Permalink
For now I will just keep the PS5 connected with with a cable.
User | Count |
11 | |
8 | |
6 | |
3 | |
3 |
