- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
2 routers, 2 separate houses,
- Mark as New
- Bookmark
- Subscribe
- Permalink
I liked the RAX70 so much at my home, I purchased another for my cabin.
Do I need to download a second App to set the second one up? Or can I use the App from my original purchase.
The first one is DHCP. My new one has a Static IP.
Any help would be appreciated. I can't get any chat help.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: 2 routers, 2 separate houses,
The nighthawk app will support multiple Netgear routers, and the one app can allow you to manage multiple routers with a simple to use menu.
The app will also allow you to manage multiple netgear routers and extenders that are connected to the same network, though for the most granular control, the web UI is still be the best way to go since the app lacks advanced settings.
• Introducing NETGEAR WiFi 7 Orbi 770 Series and Nighthawk RS300
