Burdell
Sep 04, 2020Tutor
4 Ethernet ports on back of my Router..Ethernet out?
Hi there..Question..Are the 4 ethernet ports situated in a line on the back of my RAX45
Ethernet out? Thanks!
Ethernet out?
I don't know what that means. Ethernet is two way. In and out. It is there to connect devices on your local network other devices on the network.
If you visit the support pages:
Support | NETGEAR
you can feed in your model number and find the documentation for your hardware.
Tell us what you are trying to do and you might get a more sensible response.
1 Reply
Ethernet out?
Support | NETGEAR
