× Introducing the Orbi 970 Series Mesh System with WiFi 7 technology. For more information visit the NETGEAR Press Room.
Orbi WiFi 7 RBE973
Reply
AX Routers OpenVPN Feature Request - Define IP subnet range for VPN connected devices.
3deric
Follower
Hi Netgear!  Love my new RAX80 router!
Feature Request for future firmware update:  Can you add support for allowing users to define the IP range of VPN connected devices?  🙂  Becasue of limitations in TAP/TUN support across mobile OS's and desktop OS's, some VPN connected devices are assigned IPs within the LAN IP range of the router, and some are auto-assinged IPs on other subnets. Can you add support for defing the IP range for connected devices to allow the user to specify how different VPN connected devices given IP address in the LAN?   🙂
This would help the various challenges of users not being able to connect back to their router using a mobile device, via VPN, and access their 'home' resources.
Thanks!
-3deric
Model: RAX80|Nighthawk AX8 8-Stream WiFi Router
Message 1 of 2
Christian_R
NETGEAR Employee Retired
Re: AX Routers OpenVPN Feature Request - Define IP subnet range for VPN connected devices.
Hi 3deric - We're glad to hear you're loving the RAX80! Thank you for your interest in this feature. We recommend posting your suggestion on our Idea Exchange Board:
https://community.netgear.com/t5/Idea-Exchange-For-Home/idb-p/idea-exchange-for-home
~Christian
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 1850 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
