× Attn: Nighthawk Pro Gaming members, we have recently released firmware to address a critical security vulnerability. For more information click here. .
Orbi WiFi 7 RBE973
Reply
AX1800 Extender wont connect
predsfan09
Tutor
I purchased the AX1800 wifi extender its shows connected to Xfinity modem but the client connect light is not lighting up and Netgear_Ext isn't showing up when i try to connect the device to it
Message 1 of 8
Accepted Solutions
Guru
Re: AX1800 Extender wont connect
@predsfan09 wrote:
no did not hit wps prior to using assistant when gets to wifi connection for NextGear_Ext its not found and the Xfinity Gateway shows its connected to the router but the client connect is not lit
If the xfinity gateway is showing it connected, some type of setup went on. Either using wps, using the app, or using the assistant.
The client connect light comes on when a device connects to it. And that devices is a mesh device. Meaning it uses the same ssid as the router and allows devices to roam between it and the router. so it won't show up as seperate. And if a device hasn't roamed to it, nothing is going to show for a client
If the gateway is showing it connected, it'll have an ip address for it. You can use that ip address to connect to the extender.
Message 7 of 8
All Replies
Guru
Netgear has set up a community forum specifically for the WiFi Extender products. Most of the people who watch that forum are more likely to have experience with WiFi Extender products and know how to work it better than those of us who follow this router forum. Might be more likely to find someone who has a solution if the question is posted there:
https://community.netgear.com/t5/WiFi-Range-Extenders-Nighthawk/bd-p/home-wifi-range-extenders
Thank you.
Message 2 of 8
Guru
What extender do you have?
AX1800 is a speed, not a model.
Did you hit the wps prior to trying the installation assistant?
Message 3 of 8
predsfan09
Tutor
Message 4 of 8
Guru
Thats ether a EAX14 or 15...
Message 5 of 8
predsfan09
Tutor
its the
EAX14
Message 6 of 8
Guru
Message 7 of 8
predsfan09
Tutor
thankyou
Message 8 of 8
Top Contributors
Discussion stats
  • 7 replies
  • 7066 views
  • 1 kudo
  • 3 in conversation
Announcements
Orbi 770 Series
