- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
AX1800 needing constant reboots
- Mark as New
- Bookmark
- Subscribe
- Permalink
Problem started recently, with the addition to two ring cameras to my network. I’ve not had any issues with this router in the past, except for signal coverage so I added a NG extender to the network. The router is 1 year old.
I’m having to reboot my router several times a day for the ring cameras. Today for instance, I had to do it twice in a two hour period, and no one was home using the network.
Prior to the cameras, I could run 3 phones a laptop, printer and a hardwired Xbox off the router simultaneously without issue. Now, the network won’t stay stable more than a few hours.
My firmware is up to date and other than simply needing a more powerful router, I can’t seem to find an issue. Is my problem really as simple as needing to upgrade my router?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: AX1800 needing constant reboots
What actual router do you have? AX1800 is a speed, not a model.
What firmware is on it?
What modem/gateway is it connected to?
What extender do you have?
You don't actually put why you're having to reboot? what issue is happening to it that causes you to reboot?
• Introducing NETGEAR WiFi 7 Orbi 770 Series and Nighthawk RS300
