×  Introducing Nighthawk RS700 WiFi 7 (BE) Router. For more details, please visit Nighthawk Tri-Band WiFi 7 Router.
Reply
AX4300 RAX45
MOSO
Guide
AX4300 RAX45
Any hard drive connected to this router keeps running w/out going to power down mode causing hard drive to heat up. Is this because the router keeps reindexing the drive?
Message 1 of 3
Re: AX4300 RAX45
What makes you think the router is doing this?
How is this drive connected to the router? USB? Wired Erhernet?
Is the DLNA server active?
Visit the support pages:
Support | NETGEAR
and feed in your model number and check the documentation for your hardware.
You may have done this already, but I can't tell from your message.
Just another user with a set of boilerplate macros.
My network DM200 -> R7800 -> GS316 -> PL1000 -> Orbi RBR40 -> Orbi RBS50Y -> RBS40V
Message 2 of 3
MOSO
Guide
Re: AX4300 RAX45
I am using the WD Passport 5 tb drive connected to the router using usb. What should I check on the router admin page?
Message 3 of 3
Top Contributors
Discussion stats
  • 2 replies
  • 677 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 6E
