× Attn: Nighthawk Pro Gaming members, we have recently released firmware to address a critical security vulnerability. For more information click here. .
Orbi WiFi 7 RBE973
Reply
AX5200 with PS4... What is the best set up with At&t Fiber?
o0MrChicken0o
Follower
I would like to know the best set up with the Arris modem/router and my AX5200. I have taken off the firewalls and set up the Arris to the best bridge I know how to do. The problem I'm running into is my Arris modem states im getting my 1000Mbps but I'm only getting half that when I run the routers speed test. Can someone tell me what im missing for it to only use half of the data?
Message 1 of 2
Guru
Re: AX5200 with PS4... What is the best set up with At&t Fiber?
How are you running the router speedtest? If its using the built in app, don't use it.
Use a hardwired in pc/laptop and check multiple servers. Many can't max out gigabit.
what router do you have? (Hint ax5200 is a speed)
when you put "the arris is the best bridge i know how". doesn't tell us much of if its running in proper bridge/modem only mode. And att doesn't make it easy. Have you tried simply leaving the att device in router mode (disable its wifi) and then put the netgear in AP (access point) mode?
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 774 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi 770 Series
