× Introducing the Orbi 970 Series Mesh System with WiFi 7 technology. For more information visit the NETGEAR Press Room.
Orbi WiFi 7 RBE973
Reply
AX6 6-stream WiFi Router AX 4300 Model#RAX45
dennisg9987
Follower
Hi, just installed Nighthawk router and netgear 8 port switch.
Running wired connection to my tv via netgear switch.
Netgear switch replaced older switch. T
rying to connect my roku via wired connection.
Roku set up says I am connected via wired connection to router but not connected to internet.
How do I correct this?
Thanks for any help. Dennisl
Message 1 of 2
Christian_R
NETGEAR Employee Retired
Re: AX6 6-stream WiFi Router AX 4300 Model#RAX45
Hello dennisg9987,
If you recently purchased the device I would recommend contacting our support team as newly purchased devices are provided with 90 days of complimentary support. You may open a ticket by registering your device using the link below.
https://www.netgear.com/support/contact.aspx
Christian
Message 2 of 2
Discussion stats
  • 1 reply
  • 568 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
