×  Introducing Nighthawk RS700 WiFi 7 (BE) Router. For more details, please visit Nighthawk Tri-Band WiFi 7 Router.
Reply
Ability to bulk change hosts file / filters for Nighthawk AX12 RAX120 for add-blocking purposes
abweihja
Follower
Hi all,
Just got the router, and was wondering whether I could add easylist (https://easylist.to/easylist/easylist.txt) somewhere to the Nighthawk DNS mappings/blocking without manually adding them one by one in Advanced Security Options -> Block Sites
Model: RAX120|Nighthawk AX12 12-Stream WiFi Router
Message 1 of 2
Christian_R
NETGEAR Employee Retired
Re: Ability to bulk change hosts file / filters for Nighthawk AX12 RAX120 for add-blocking purposes
Hello,
If you recently purchased the device I would recommend contacting our support team as newly purchased devices are provided with 90 days of complimentary support. You may open a ticket by registering your device using the link below.
https://www.netgear.com/support/contact.aspx
Christian
Message 2 of 2
Discussion stats
  • 1 reply
  • 501 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 6E
