× Introducing the new Orbi 770 Series Mesh System. To learn more click here.
Orbi WiFi 7 RBE973
Reply
Access Denied after update to firmware version v1.1.4.28
adavidso
Tutor
This issue is still a problem where login becomes impossible through a browser (only when internet is connected on wan port). Only solution is to roll back to earlier firmware and factory reset and turn off auto updates. Really frustrating and a huge waste of time.
Message 1 of 5
Re: Access Denied after update to firmware version v1.1.4.28
Not much to go on there.
If there is one it might help if you told people the make and model number of the modem/gateway/ONT that connects this router to the Internet. Is it, by any chance, also a router, with a set of LAN ports on the back?
I ask because a lot of people turn up here trying to put a router behind a modem that is also a router. That can complicate troubleshooting.
Message 2 of 5
adavidso
Tutor
Thanks for the reply. This thread is about a defective firmware update first identified here: https://community.netgear.com/t5/Nighthawk-with-WiFi-6-AX-and/Access-Denied-after-update-to-firmware....
That thread was "solved" however I wanted to be clear that the solution required a rollback to previous firmware and turning off automatic firmware updates, so it is not really solved.
My ONT is a Nokia modem only with no extra ports or router functionality. This is not caused by double NAT.
Message 3 of 5
So your message cropped up with no connection to past discussions.
I think there were several conversations on that issue.
This seems to have been the most useful contribution:
Solved: Re: Access Denied after update to firmware version... - NETGEAR Communities
Then there was this:
Solved: Re: New - RAX41/42/43/50/54 V2 Firmware Version 1.... - NETGEAR Communities
As you say, it isn't SOLVED but there were workarounds to get you out of the immediate hole.
Message 4 of 5
adavidso
Tutor
Agreed, and thanks for this. I suggest that this thread remain unsolved until either 1) firmware 1.4.28 is fixed or 2) a subsequent firmware is released that solves this issue.
Message 5 of 5
Top Contributors
Discussion stats
  • 4 replies
  • 1129 views
  • 5 kudos
  • 2 in conversation
Announcements
Orbi 770 Series
