Jrtyrrell's avatar
Jan 26, 2020
Activate on Xfinity Internet with CM1150V
I’m tired of paying $14 per month for rental of my cable modem and router. I have the AX12 in access point mode and is connected via Ethernet to the XFi gateway. I tried installing the CM1150V, activating my service and then connected port 1 to AX12 internet port. After 45 minutes the internet LED was blinking and never connected to the internet. Any ideas? The WiFi SSID on the XFi gateway is different than the SSID on the X12.
I’m wondering if I need to change from access point mode to router mode prior to starting with the activation of the CM1150V.
Thanks for any suggestions!
  • plemans's avatar
    Jan 28, 2020
    The XFi gateway has too much depth to fit into my electrical panel in the basement, the saving grace of the CM1150V.  XFi gateway is D3.1, the cable modem/router I had from Comcast before was 4 port and all 4 ports worked,-----Thats because it was a combo device. Meaning it had a modem and a router integrated. The CM1150V doesn't have an integrated router.   but was only D3.0.  My internet speed is 600Mbs download so I need a D3.1 modem.
    If only 1 port of the CM1150V works, what's the point of having 4 ports? ---Whole purpose is for business lines that are allowed multiple public IP address, the rare ISP that allows consumer lines to have more than 1 public ip address (rare), or for port aggregation on ports 1-2.  i wouldn't recommend port aggregation currently as its been a bit flaky. Most consumer's aren't going to need the CM1150v unless they have gigabit and need voice. Same as most consumer don't need the 4x ports on the CM1200. We run into this a lot
    So again, unless you're using port aggregation, only port 1 is useful for most people.
    so go:
    CM1150V--------> AX12 (port 1)------->Devices and switch
    don't use the other 3 ports on the CM1150V unless you plan on using wan port aggregation.
  • plemans's avatar
    The cm1150v is a modem only device. so yes your AX12 will need to be in router modem
    You'll also need comcast to activate the modem. Some devices have the auto activate feature.
    https://kb.netgear.com/24939/NETGEAR-Cable-Modem-Router-Online-Activation-with-Comcast-Xfinity-service
    If it doesn't work to activate, you can call in to activate.
    If that doesn't work, let us know.
    I'd also avoid link aggregation at the current time as its been a bit buggy.
    • Jrtyrrell's avatar
      Jrtyrrell
      Tutor
      plemans - that worked, I changed to router mode and worked with the XFi Gateway.
      Step 2 - I had to call Comcast to get the CM1150V activated so they could see it.
      However, only devices that can connect to the internet are the devices are connected to the CM1150V.  Wireless devices can't connect to the internet, they did with the XFi gateway.  Nor can my latop that is connected to an ethernet port on Nighthawk AX12 connect to the internet.
      The ethernet cable connected to port 1 on the CM1150V is connected to Internet port on Nighthawk.
      What am I missing to get this to work?  Frustrating....
      • plemans's avatar
        Are you using both the Xfi gateway and the AX12?
        How exactly do you have it setup? I'll lay out an example for clarity that *should* have everything working
        CM1150v------>Xfi gateway (in router mode)------->AX12 (in AP mode)
        CM1150v------>AX12 (in router mode)------->Xfi gateway (in AP mode).
        Or if you're only using 1 device
        CM1150v------>AX12 (router mode)
        CM1150v------>Xfi device
        any time you switch whats connected to the CM1150v, make sure to reboot it and the device connecting to it. It needs to reboot to reassign the public ip address.
        I've never used the xfi gateway so I'm unsure of its modes/functions.
        I do know the CM1150v has multiple ports but with xfinity, basically only port 1 works. Make sure you don't use the other ports unless you're using link aggregation. And that still only works for 1 device.
