- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Adding a fan to RAX120
- Mark as New
- Bookmark
- Subscribe
- Permalink
I know about the internal fan and about the debug option but that fan doesn’t stay on all the time hence why I want to add a fan via usb ports that are located in the back.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Adding a fan to RAX120
Yes you can. I've seen it done in several posts
also in AP setup: RAXE500->EAX80
1.4gig download/50mbps upload from Xfinity
We’re members of the public helping out on our own time.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Just get a laptop cooler and place it underneath the router and plug it in the USB port. It's what I do for my router.
Switching: 2x NETGEAR 8-ports (GS108v4) / 1x NETGEAR 16-ports (JGS516v2)
Desktop: AMD Ryzen 7 3700X - Server: Intel Core i7-7700K - NAS: Intel Pentium G4400, 20 TB
- Mark as New
- Bookmark
- Subscribe
- Permalink
Yes, you can swap out the fan for the RAX120. The stock OEM fan that the RAX120 uses is a 50x50mm fan made by Delta. You can see the in the FCC photos, https://fccid.io/PY317300397/Internal-Photos/Internal-Photos-Part-2-3990332 the model number. The only fan that I have found that matches the OEM fan, is one made by Fractal. Hope this helps.
I should add, the page where I got the internal photos is https://fccid.io/PY317300397
You can see the that the RAX120v2 was undergoing FCC testing in Oct 2020 & the initial RAX120v2 firmware release was in Dec 2020.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Would be much easier to avoid any router intrusion and fan frustrations and install a laptop fan cooler under the router.
I keep one under any router I use 24/4 for additional cooling. works well:
I use this one: https://www.amazon.com/Thermaltake-Massive-Adjustable-Notebook-CL-N004-PL20BL/dp/B00IGSATZY
My Setup | ISP SparkLight | Internet Cable 1000↓/50↑ CAX80 Modem Mode | Wifi Router MK83+ (Router Mode) | and RBK853 (Router Mode) | Switches NG GS105/8, GS308v3, GS110MX and XS505M | Additional NG HW: C7800/CAX80/CM1100/CM1200/CM2000, Orbi: CBK40, CBK752, RBK50, RBK853, RBK752, RBK953, SXK30 | NightHawk: MK63, MR6150, R7000, R7800, R7960P, R8000, R8500, R9000, RAXE500, RAX50, XR450, XR1000, EX7500/EX7700
