× Introducing the new Orbi 770 Series Mesh System. To learn more click here.
Orbi WiFi 7 RBE973
Reply
AirPlay to HomePods not working with Smart Connect
aellsworth
I’ve had this router for a year now. For the first four months it worked great, but the last 8 months I haven’t been able to use the Smart Connect feature. When enabled I’m unable to AirPlay my music and podcasts to my HomePods. From what I can tell, it looks like HomePods / Apple TV’s on the same band appear on my phone. Had anyone else had this issues? Is there any solution other than turning off Smart Connect and having everything on 2.4GHz?
Model: RAX80|Nighthawk AX8 8-Stream WiFi Router
Message 1 of 10
Christian_R
NETGEAR Employee Retired
Re: AirPlay to HomePods not working with Smart Connect
Hello aellsworth,
I would check to see if your RAX80 is due for a firmware update.
Christian
Message 2 of 10
aellsworth
Hi Christian,
Thanks for the suggestion, but I check and apply updates every week.
Message 3 of 10
Christian_R
Hello aellsworth,
May you provide me wit the current firmware version number your router is on.
Thanks,
Christian
Message 4 of 10
aellsworth
V1.0.3.106_1.0.50
Message 5 of 10
mixmaven
Star
Same issue, broke Apple HomeKit as well (again).  Engineers seem to break homekit about every other release!     V1.0.3.106_1.0.50
Message 6 of 10
ik8sqi
Star
See my post from last year - Netgear broke HomeKit from their 1.0.3.88 firmware and up. None of the newer versions are able to work with HomeKit when SmartConnect is enabled:
https://community.netgear.com/t5/Nighthawk-Routers-with-WiFi-6-AX/RAX75-1-0-3-88-firmware-broke-Home...
If you're willing to sacrifice the security updates, you can downgrade to firmware v1.0.2.76 which is the last version I found able to work with HomeKit/SmartConnect.
Message 7 of 10
Have you tried disabling 'Smart Connect"?
Message 8 of 10
mixmaven
Star
Yes, smart connect and OFDMA is disabled.   It was a firmware issue.
Message 9 of 10
Are your Homekit smart devices still working?
Message 10 of 10
Discussion stats
  • 9 replies
  • 2089 views
  • 0 kudos
  • 5 in conversation
Announcements
Orbi 770 Series
