× Introducing the Orbi 970 Series Mesh System with WiFi 7 technology. For more information visit the NETGEAR Press Room.
Orbi WiFi 7 RBE973
Reply
Armor Free Trial Error
BS50
I had to reset to factory default settings on my RAX200.
Now when I go to the app on my phone (Android) Netgear Armor Security panel has an Activate Trial button. When selected I get a failed to subscribe error message.
I have tried rebooting the router
I have re-installed the app
I have turned on and off remote management
I have tried on another device
I have tried to go to Add ons in the app to purchase it (if available). The only option available is pro support. No help there.
Previous to reseting to factory defaults. The router set up with the free trial version of Netgear Armor working normally.
How do I get the free trial activated so that I can purchase it?
Firmware version v1.0.2.98
Model: RAX200|Nighthawk Tri-band AX12 12-Stream Wi-Fi 6 Router
Message 1 of 5
Christian_R
NETGEAR Employee Retired
Re: Armor Free Trial Error
Hi BS50,
May you send me a private message with your contact info and serial number. I'd like for our support team to reach out for further investigation.
Christian
Message 2 of 5
CAmbr52342
Tutor
Hello, I just updated to the most recent firmware after completing a factory reset. I am experiencing the same problem. I cannot activate the trial so I can purchase Armor. I had an expired trial prior to uploading the newest firmware.
Message 3 of 5
BS50
I am still working to resolve the problem...
Message 4 of 5
Christian_R
Hello CAmbr52342 & BS50,
May you reinstall the Nighthawk or Orbi app and let me know if your issue persists.
Christian
Message 5 of 5
Top Contributors
Discussion stats
  • 4 replies
  • 833 views
  • 0 kudos
  • 3 in conversation
Announcements
Orbi WiFi 7
