× Introducing the new Orbi 770 Series Mesh System. To learn more click here.
Orbi WiFi 7 RBE973
Reply
BROTHER EASY SCAN TO EMAIL APP CONNECTION ERROR 03 PORT 80 443 Nighthawk AX4: RAX40 port forward
kevinm10
BROTHER EASY SCAN TO EMAIL APP CONNECTION ERROR 03 PORT 80 443 setup as port forwarding in/out with printer ip but printer errors with connection error 03 and proxy is disabled on printer.
Anyone have this issue or know what else to configure on router to allow installing the app on the printer?
also reached out to brother.
Prints fine via network.  Scans to pc on same network.
Get connection error 3 if selecting web or apps on printer menu.
Manual says disable proxy (done) or add ports 80 and/or 443 to router pass through.
Printer model is MFC-L2750DW
Message 1 of 4
Accepted Solutions
kevinm10
Re: BROTHER EASY SCAN TO EMAIL APP CONNECTION ERROR 03 PORT 80 443 Nighthawk AX4: RAX40 port forwa
After further research rebooted the router, after adding the port forwarding rules, and it's working.
Solved.
Message 3 of 4
All Replies
Guru
Something to contact the mfr about regarding there printer product.
Message 2 of 4
kevinm10
Solved.
Message 3 of 4
Guru
Glad you got it working. Please mark your thread as solved so others will know. Be sure to save off a back up configuration to file for safe keeping. Saves time if a reset is needed.
https://kb.netgear.com/24231/How-do-I-back-up-the-router-configuration-settings-on-my-Nighthawk-rout...
Enjoy. 📡
Message 4 of 4
Top Contributors
Discussion stats
  • 3 replies
  • 383 views
  • 1 kudo
  • 2 in conversation
Announcements
Orbi 770 Series
