× Introducing the Orbi 970 Series Mesh System with WiFi 7 technology. For more information visit the NETGEAR Press Room.
Orbi WiFi 7 RBE973
Reply
Blocking Browser extensions at the router
llamaman
Follower
Hi,
I noticed the Netgear Family Control doesn't block browser extension VPNs.  Is there a way at the router to do this (I tried blocking VPN services but the bowser extensions still work):
block the ports they use?
I see you can add to the executable to disable them; but does the new executable redirect to different servers like it does with safe search?  Or is there a script I can run on a machine to force the executable with the disabled flag for Chrome and Edge?
Message 1 of 2
Accepted Solutions
microchip8
Master
Re: Blocking Browser extensions at the router
It is not possible to block extensions at the router level.
Message 2 of 2
All Replies
microchip8
Master
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 919 views
  • 1 kudo
  • 2 in conversation
Announcements
Orbi WiFi 7
