Orbi WiFi 7 RBE973
Reply
C7000v2 Nighthawk app says Router not supported
arianeny1
Follower
My Nighthawk goes from saying that "Firmware Out of Date" to saying "Router is Not Supported"
Regardless - How do I update the Firmware so that the app will work on my phone?
If I have the most recent Firmware then my speeds should go up, yes?
Message 1 of 2
Guru
Re: C7000v2 Nighthawk app says Router not supported
You don't.
combo devices (integrated modem) can only be updated by the isp. Not by individuals.
Its the problem with combo devices and modems. The isp controls the firmware.
https://kb.netgear.com/000036375/What-s-the-latest-firmware-version-of-my-NETGEAR-cable-modem-or-mod...
If I have the most recent Firmware then my speeds should go up, yes?------What speeds do you pay for? What speeds do you get? A firmware upgrade isn't going to increase your speeds. Upgrading them from your isp will.
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 1212 views
  • 1 kudo
  • 2 in conversation
Announcements
Orbi 770 Series
